- Dec 11, 2013
- Iowa, in the boonies
- My credo
- When life is passing you by, downshift!
I'm aware as long as you keep your foot out of it you will be issue free, but i had came across something that concerns me a little bit. Upon going through the tech articles on the d28 to d35 swap i had noted you would need to shorten the driveshaft about 1" to 1.5" Normally i wouldn't see this as an issue, but when we swapped the 4.0 we used the m50d. Keep in mind that the m50d is about 3" longer than the fm145 was. We did keep the stock front driveshaft out of the ranger thinking that it would bolt right in. I am now concerned on how it will fit. Could it be 1.5-2" short of where it needs to be, or am I worrying about nothing? Also the bronco has an estimated 3-4" of lift on it. FYI we DO have the d35 from the ranger if needed. It will just need re-geared. as it's 3.27 whereas the bII came with 3.73. Thanks in advance
-Lariat
-Lariat
So the bronc is not moving for awhile.
