- Oct 28, 2008
Hello all, my 98 4.0ohv with 148xxx miles has exhibited symptoms of a vacuum leak since I bought it, LTFT's both at +25 at idle, falling as engine load increases to 0 at WOT. Classic vacuum leak symptoms. I did upper and lower intake gaskets this summer, with injector orings as well. Still have the high fuel trims and slightly shaky idle. Not terrible, but I can feel it miss here and there.
I decided to smoke test the intake yesterday, and saw smoke from 2 areas; the little breather on my IAC valve, which is only a month old, and under the EGR valve, looks the be from the little diaphragm holes. I definitely have a leak, even when I plug the intake and IAC breather, I am able to suck air in through the vacuum like, sounds like its leaking in either through the EGR valve or somewhere near it. My question is, are these 2 valves supposed to leak?
If I cover the IAC breather while truck is idling, the idle doesn't really change, but the IAC starts vibrating and makes a faint hooting sound. The reason I replaced IAC was the old one was hooting very loudly.
