Hi All,
After a rebuild of an engine and a new clutch disk (and resurfaced flywheel) I put everything back together. There was nothing wrong with the clutch and I while it has 150,000km on it I did not want to completely overhaul the clutch so I just settled for a new disk.
When I put everything back together (fight of my life to get engine to mate with tranny) I noticed after bolting most of everything back... that the clutch pedal was very soft. I tried pumping ~25 times with no luck. I also made sure that it actually wasn't disengaging the clutch. The hydraulic system was never opened. I had thought that I damaged something by bolting the transmission to the block to mate it. However I pulled everything back out and nothing appears out of place.
I only have a few ideas...
1. Overmachined flywheel?
2. Applied too much force to fingers to get adjusting ring rotated on pressure plate? I did this one bit at a time until i could move the ring.
3. Air in system... somehow..?
4. Clutch disk installed backwards (however I'm fairly certain I did this right)
5. Bad pilot bearing?
I could change gears just fine before I removed the transmission. When I had looked into the transmission the throwout bearing was moving and making some contact with the flywheel. Though it was hard to see much.
That said, I really don't know where to take it from here. I've posted some pictures if anyone can suggest things to check...
