1987 4x4 Ranger front end camber.
luftwaffle
10+ Year Member
Hey guys, my Ranger for some reason has an issue with the front end. The tires on the front end go from having positive to negative camber and vice versa as I drive it. I only moved it a little as its been sitting for awhile. Any idea what is causing this??
Bad ball joints come to mind first.
I'm not a guru but I would check all your components for wear first; rad arm bushings, etc. Bad toe in could lead to what you describe too.
Good luck,
Richard
Edit; ^^^^that too. lol. Sometimes I should wait a bit before answering.
Good luck,
Richard
Its all good, haha. Thanks for the response man. My poor truck has been sitting all summer, cant wait to get it back out in the dirt!
Ball joints mine did the same thing my universal bearing was as well..
Sent from my SCH-I535 using Tapatalk
weak springs
