- Jun 10, 2011
few updates ... for a top end gasket kit from felpro and head bolts as well ... my heads are back from the machine shop.. complete and clean.. had a 3 angle valve job, new valve gides , new springs and retainers they machined everything smooth and put a coat of royal ford blue on them ...
started cleaning and sandblasting everything and coating it all with some duplicolor engine enamel.. the valve covers will be replaced latter on as I have to clear the roller rockers that i ordered ..
I found a 97 merc mountaineer 5.0 in the you pull yard and grabbed everything off the front of the motor power steering pump and bracket . alternator and bracket .. also got the upper and lower intake and the heads .. Brought it all home cleaned it and painted it all ...
