- Oct 14, 2010
- Williamsport, Pa
I've had it on there for a little over a year, the bent part is actually stronger. It has bent, but on the flat part on the passenger side right next to where it attaches to the frame. I keep thinking I need to get in there and do some gussets. not sure what i'm gonna do on that flat part, I've toyed with the idea of another piece of 1/4" on top and making it double shear but it would be a bitch to get in and out with the driveshaft in.
I cut out the whole top and set the angle in so it was flush with the outside skin and welded it in fully and ground it smooth, the inside is welded in a couple spots just to hold it in there.
Good deal, I'm glad it's working for you. I went slightly overkill on mine....
