- Aug 7, 2007
That's an OH S**T moment.
There are extractors for that, but I believe you have to drill into the spark plug. That's hard on an installed engine. You need to coat the drill bit in heavy grease (like wheel bearing grease) to keep the shavings out of the cylinder. You don't want that crap in the cylinder -- cylinder walls are just your everyday soft cast iron, and they will score.
If that doesn't work, I don't think you have any option short of yanking the head.
It doesn't take all that much force to break a spark plug if the socket isn't ALL the way on (so it's off square). But usually, that breaks the ceramic off and the hex head is fine.
I'm trying to picture a spark plug where the hex part isn't integral with the threaded part. This isn't a 100,000 mile plug by any chance, is it? Witha S**TLOAD of rust?
This isn't a problem I've had to deal with in a real situation (only classroom), since I use cheap spark plugs and just replace them every 30,000 miles. I HAVE cracked an insulator by being stupid, but not a hex head.
