- Apr 21, 2012
Hello everyone,
I've lurked the site for a few years and finally made an account. Now I need some help.
First off my Ranger:
91 XLT, 4.0L, 2wd, Auto. She was my first when I turned 15 and taken care of her ever since. She's had a few mods over the years as well. K&N drop in filter, BBK TB, e-fan, Jet performance chip, rear cat delete, aluminum driveshaft, and Flowmaster super 40 w/ turndown.
Here is a picture from a month or so ago..
Now on to my issue..
The 4.0L is getting tired and doesn't have the pep that it use to. (120k miles). It's suffered from the known lack of oiling issues with the push rods and valvetrain and sounds like a diesel when first started and a little through the RPM's.
I have an 87 LTD with a 5.0L that I plan to swap over. For right now I just want to swap the restricted 5.0 on over as it is just to keep the down time to a minimum since it is my daily. I'm trying to keep the miles off my 500whp monster STi..haha
I've got the list for everything mechanically I will need to fit the motor/trans in the truck. What I'm stuck on is wiring. The LTD basically runs on a standalone. The engine harness runs to the firewall and plugs into the ECU. Thats all fine and dandy, but what do I do about interior wiring? Do I pull the box out of the LTD and rewire the Ranger or does the Ranger have its own separate interior control box? I know the RPM wire goes to the 4.0L ECU so I would have to figure out how to make it work with the 5.0 ecu, but what about everything else like water, oil, speed, temp, and volts? Do I just leave the 4.0 wiring intact and splice the 5.0 sensors in?
I've built my fair share of cars so it all sounds easy enough, but I'm kinda stuck here since everything I've read so far is either someone with a similar setup uses an Explorer 5.0 and its an easy swap over or they use an old school 5.0 and go carb.
