PlumCrazy's Build
Hey Brad, could you do a flavor for me wben you get home tonight...
Measure from weld to weld on your rear shaft. Im not worried about the slip yoke.
Sent from my DROID RAZR using Tapatalk 2
No problem. I have a 1 pc shaft. I assume you do too.
Yup. reg cab long bed wheel base is 11" shorter than mine, but I removed 8" or so of shaft for the doubler, so i think i may be able yo use a reg cab long bed shaft for a spare.
I may even put a double card joint at the tcase end, which would add 3" or so and be perfect
I have a 4 door expo shaft, but i need to add a lot to it.
My rear drive shaft: 41" from the axle side yoke weld to the back of the double card joint. The double card joint is 5.5"
Wheelin 3-16-13
PlumCrazy's Build
11
I think pulling you out on full tilt at the end of the day killed my alternator. It drove fine the whole way home with all electronics working, but I stopped at Subway in Toledo and when I came back out it wouldn't start. My roommate jumped me and it fired right up just like on the trail.
I have a 95A I can ship to you if you want..
It's fine I'm going to upgrade to a 130A so hopefully it won't happen again. I have been wanting to do the upgrade for awhile now, I guess now is a good time.
Okay.lol I feel bad now
Wait, when did you hit Full Tilt?
Sent from my HTC VLE_U using Tapatalk 2
Not Full Tilt. The new Mild to Wild. That dude in the white jeep cut the tape and let us run it. It's really tight. Smashed my bed pretty good.
1.5 miles of black trail. Or play it safe on the blues. Brad and I ran the all the blacks. I didn't make it through the last hole. It was getting dark and i didn't want to try again after Pat pulled me back out.lol
Few goodies I picked up for the SC build.
Swapped the 30 psi for a 20
PlumCrazy's Build
NGK 8mm wires.
PlumCrazy's Build
Also picked up an air box off a Lincoln that is setup like the 95 Ranger box, but has a bigger inlet and 90mm MAF.
PlumCrazy's Build
PlumCrazy's Build
PlumCrazy's Build
Built a breather manifold for the rear axle and t case(s)
PlumCrazy's Build
PlumCrazy's Build
PlumCrazy's Build
PlumCrazy's Build
Bundy was fun...super muddy and sloppy. Took a bit of body damage, but no other breakage. Just full day of decent wheeling. Definitely got pretty wild towards the end of the day.
I need a Go Pro fo sho......and a winch.
PlumCrazy's Build
PlumCrazy's Build
PlumCrazy's Build
Everything is soo muddy.lol
PlumCrazy's Build
I picked up a winch mount off 5speedin2.3 as well.
