- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- My credo
- Love Thy Neighbor
I don't use the synthetic oil...just regular oil...and if you want to use either in a heavier format I'd say it might help some...the oil leak can be a problem either way though...and if it is the valve cover I'd recommend the blue rubber valve cover gasket as opposed to the cork...a bit more expensive but I think it is worth the extra expense...
I used the Rotella Diesel but recently switched to Castrol Xtection 10w40 (sp) diesel oil and have had slightly better results...meaning the smoke has almost disappeared with startup...
The smoke that I was referring to was not actual smoke from the tailpipe but more like a steam from the valve cover vents and through the PCV...I had it vented to a catch can and run back through the breather (carbed application) as well as through another smaller oil/air filter...
But, anyway...there was/is a blow-by problem with my engine...as well as valve seals...and I'm in the process of swapping heads...did discover quite a bit of carbon on the pistons...so I might try the seafoam once I get it running again...just a bit reluctant to do anything like that...
