- Dec 27, 2012
I have a 92 ranger 4.0L .It started acting like the coil pack was breaking down. I replaced the coil pack, no difference. I then changed plugs,wires,crank sensor,and throttle position sensor( had a crack). Changed fuel pump and filter, still the same.It is hard to start( especialy when cold) runs very rough, when you press the excellerator it bucks or stalls.Will not rev up past 4000. once in awhile the engine light will go out and it idles fine and has the power it should have, but this is very seldom the case. I am not sure if the temp sensor or cam sensor could cause this. Can anyone give me some direction.
Thanks,
Robert
Thanks,
Robert
