- Dec 6, 2009
- maplevalley WA
Getting stranded is never a laughing matter. Try disconnecting the battery for 1/2 an hour and see what it does. There is no way to test the computer but resetting it might tell you if it is working, it will reset the values and then as it runs all the inputs may throw it out of wack again maybe a bad sensor engine temp, IAT, Map ect.. Clean all the connectors and intake air temp with electrical cleaner with the battery disconnected. Start it up and if it runs better the computer is likely good and after it runs and if it goes south then bad inputs or bad wiring is suspect. If you change the computer and have the same issues then you probably have two good computers chances are next to zero two computers have the same faults! Look at the wire/s going to the O2 sensor in the exhaust manifold alot of times intermittent faults are related to a wire shorting out part time and will throw the computer waco. GL
