Back from Moab
CheapThrillB2
May 2010 OTOTM
Western Michigan
1975-1995 Ford
Back from Moab....5 days might be to much for a d35 IFS :sonicjay:
Found the sway bar links gradually were torn apart through the week, and my inner tie rods gradually got more and more play everyday. Enough that I bought a spare at about day 3. Also found the front shocks at the upper mounts gradually got worse as far as the washers and bushing getting torn up, enough that at day five the RF tore apart leading to a cv axle failure. Haven't rechecked the front end and my drive home of 40 or so miles was pretty rough when we got back to Michigan. Assuming I got alot more issues then I know about.
Lots and lots of scrapes and dents on my torision bar mounts, gas tank skid, fuel tank skid, and my rear hitch was a big pita everywhere. My stock l/s in the 8.8 worked awesome though on the rocks and everywhere else. Side steps got readjusted alot through out the week.
Ran alot of trails that the explorer was underrated for and did very well. Winch wasn't used till the last day after I lost 4wd. And we ran all of the obstacles and no bypass's till that point. Now for pics, I have videos I need to organize and upload...
Back from Moab
Hot Tub-drove in knowing I wasn't driving out. Intentionally knew it and winched out.
Back from Moab
Back from Moab
On top of the world
Back from Moab
Back from Moab
Back from Moab
Back from Moab
Back from Moab
Back from Moab
Back from Moab
The 5.0L and a true 4-lo were priceless.
What trails did you run?
Fins and things. Hells revenge. Kane creek. Long canyon. Gemini bridges. Bull canyon. Dome plateau. Top of the world. Poison spyder mesa. Golden spike. Gold bar rim.
Esc when you break a cv axle on the golden crack and finish out gold bar rim in 2wd. WOOT for v8 and awesome tires.....the winch helped a few times. We made it out of gold bar rim about 20 minutes before sunset and it started sprinkling about that same time. We got lucky.
that's a long ass day of wheelin, huh?
I didn't know you had an exploder.
The wife has the same one to...
Same yr, motor, options, tcase upgrade, lift, tire size. Only difference is colors and mine has DTRL and 100K more on the odo.
looks like fun. what tcase are you running?
Took us 15 hours. Had a WJ blow a unit bearing on PSM, then a u joint strap on golden crack. We used his winch a bunch too. Lol
Yes it would. And theres a link on explorerforum to the swap. I will post it when i get a chance.
Schweet. Thanks dude
