- Oct 1, 2009
- Raleigh, NC
Yeah it will be fine. They have to get pretty hot to cause a problem I have sold lots of axles and guys would text me after they installed it and say the axle is making this howling noise. I would ask did you put oil in it? And I would get oh crap comment back. LOL One guy drove it like 6 blocks.Reason you can get away without oil in them for awhile is they use roller bearings so a lot less friction going on in there. One of my customers actually drove 10 miles and grenaded his Dana 35 since he never checked it. I felt bad so I fixed it for free but made him buy the parts.
i dont care who i buy an axle from. i dont do anything with it until i've popped the diff cover. that's just common sense lol.
Looks good bro. Is it just me, or is your caster WAY off on that front passenger tire? Shock length looks perfect to me.
He probably just needs adjust his toe that or he has bad ball joints or both. And you are right shocks look great to me.
the front pass tire has been giving me issues. i already replaced both ball joints on it. i need to go back and make sure everything is tightened on it. it also needs a real alignment. gonna take it to my buddy at just tires once i get the registration sorted out. my parents let it lapse. i need to move it over to my insurance as well.
i'm just worried about bottoming out the shocks out back. i'll run them and see what happens. also, i was thinking last night, i'm probably gonna toss a 1" block out back (or make my own from 1/4" or 3/16" steel) so i can even it out. you can tell in the pics that the front sits up higher than the back. i'm gonna get some used 33" mud tires and i need more clearance out back.
and tell me what yall think about this, a guy on another forum suggested it
making good progress. I would try too get a drop pitman arm for the steering and lower the track bar to match. You got some fairly steep angles going on that set up. I'd also drill it for a 1 ton chevy TRE while I was at it. This would be better for the continuous angle the steering is goin to see at the box. Is your transfer case have the slip yoke frt output or the slip? Mine is a slip style case. I had to clearence the yokes on my Ranger and B2 when I swapped my axles, but I was also running a low pinion 44.
