Work Boots....
AngryLepercon
Maryland
I am in need of a good pair of boots.
I have had red wings and either the quality has gone to hell or I am hard on boots. On my 3rd replacement this year and they will not replace this pair that is falling apart.
I have guidelines to follow as well which are: (must have)
- metatarsal guard
- steel toe (composite toe preferred)
- electrical, oil, and puncture resistant sole
Would be nice to have as well: (not needed)
- waterproof
- insulated
Heard good things about georgia but want to hear other options.
We just had this discussion not long ago. Do the search thingie, Bro.
I did search.........
Out of the entire thread not one has all my requirements.
Half are hunting boots.
Apparently i'm the only one that faces a $1k personal fine if caught without required PPE.
I have looked up some (but not all) of the manufacturers in the thread and nothing fit the bill.
Bro.
Up here the local store carries comp. toe in the Dakota line only. The rest of your requirements you'll have to research in that line. I'm wearing a pair now and I give them a 9/10 for comfort and 7/10 for quality. Cost was up there at $175.00. My main concern is comfort and weight, I'm on my feet all day with bad knees.
Good luck,
Richard
Wolverines are a good boot, I had a pair of their mocasin toes that lasted bout 4 years. look into a good insole to help with your knees, kinda know ur pain I have deterierated ligiments in my knees so I have never kept the original insoles in any work boots Ive had, like standin on card board, I have the dr scoles.Im on my feet 10hrs pretty much standin still and I only get mild discomfort at the end of the day.
I've had pretty good luck with Timberlands, I'm almost sure they make a boot that meets your requirements.
I have these. I forgot the exact name of the other boot, but it was brown, steel toe, and very similar to this. I think that was slightly more comfortable, even though it was grams heavier. Although this is a really good boot, it does not appear to be a grounding / "electrical" shoe.
http://shop.timberland.com/product/index.jsp?productId=4208424
Otherwise, I would recommend this. It's a rubber sole, so I don't think it is of the grounding nature.
I own two pairs of whites boots. They're custom built and my first pair lasted me 3 years fighting fires. Theyre completely rebuildable and very comfortable. I've been having issues with the sock liner coming loose and sliding though. I am constantly in the mountains on hill sides which is causing it. There's also a equally good boot company called Nicks which is who I'll buy my next pair from. Both companies have quite a few specialty boots and all are custom built to fit your feet.
Bro.
Hmmm. I have combat boots in three different shades of color. Waterproof and all that. Have you looked into them?...Navy Amy stores? I also use Walmart work/saftey boots since they last me forever and are such a delight to wear. Check Ebay as well and search for your specs there. Never heard of this $1,000 fine you are talking about....very odd indeed.
Thanks for the replies on this I will check into the custom boots, timberlands, and combat boots.
I am in sand and gravel with both wet and dry processes used. Its like walking on sandpaper constantly. Im a welder so a external met. guard saves laces. I am in boots for 12+hours a day.
Straycat. Its hell when a federal inspector shows up anytime any day unannounced. The government needs money and they write citations for anything.
Edit: MSHA COFR part 56 subpart N code 15003
I'll say I had a great pair of Timberlands. I only needed a steel toe when I was doing plastic welding (We put together the enormous tanks holding acid for galvanizing metal; they gotta be plastic) so I don't know about the guard for the laces. Insurance is a little less dangerous :)
