Bronco II SAS Dana 30/8.8....
looks awesome per usual stang. i'm really digging that paint scheme on the b2. too bad they dont make them like they used to.
Is there a way to do this with keeping the lift to like only 2"? Each rig you work on turns out sweet!
You could but you would have to do the track bar different then I have done on the last few rigs. Either have a bent track bar or move the axle bracket to lower spot. And you might have to do bump stops. The owner picked up the BII last night he seemed pretty happy with it. Thanks I love how this one turned out. :icon_thumby:
Thanks!:icon_cheers: Yeah it is too bad. They are really cool trucks. This one is pretty nice and no rust.
Do you have to chop the main crossmember up under the motor at all?
Not on any I have built so far. Double R was closest since I moved the axle forward. But it was still fine.
Nice work, man! Does the owner of that B2 live in Utah by chance? If not, there is one I see sometimes that is it's identical twin.
No it is a local truck. Thanks!
Subscribed! Super cool man!
Ok cool. One more question. How do you make the D30 work in 4x4?
put it in 4wd and go. no hubs to lock on them. unless you install an absurdly expensive set of locking hubs ($1000+ for the kits)
The drivetrain is so light it doesn't hurt your mileage.
The drive line spinning all the time doesn't damage the T-Case?
No the case uses a chain. And the chain keeps oil moving inside. If anything it helps your Tcase last longer cause the guts are all moving the same speed(but not engaged) and oil is moving all the time.
All 98 and up Rangers the tcase spins all the time since the axle shafts spin all the time.
