2003 exploder= biggest P.O.S. I've ever owned
backwoods
10+ Year Member
Wadsworth, Ohio
Just a quick little rant. :nopityA:
I've never towed with the vehicle. It has never seen dirt. Never been wrecked. Has 130k miles.
Since I've owned it, I've rebuilt the rear end. Replaced both front axles. Repaired the transmission. I have to do ball joints and wheel bearings in the front EVERY year. Sometimes twice a year. Tonight I get to dig into the rack on it. Seals are shot and there is so much play in it, I thought a ball joint was broken. Every other rear I replace the springs. Not from wear, but because they will crack. (I've never seen that on any of my road vehicles).
The hinges on the rear lift gate break every couple years. The lift gate literally cracked through. Not the glass, but the frame. It has NEVER started on the first key turn. It drinks about 2 quarts of oil between 5k changes. I don't even want to list all the electrical issues like the door sensor which had killed several batteries and randomly sets off the alarm, no matter how many times I replace it.
I loved my f-150s, my mustangs, Bronco & bronco II, and now my ranger. Even loved driving my '65 falcon year round. (great car in the snow). But this explorer is the biggest piece of junk I've ever owned.
:temper::pissedoff:
How long have you owned it?
Rear end problems are somewhat common, the axles I can see having at least blown the boots by now, and "repaired the trans" covers a lot of area. Did it need a valve body, the sleeve for the OD servo, or a total overhaul?
That is excessive in the extreme. What brand are you buying?
The rack seals will wear out after a while. Most vehicles I see that are 2005 and older have had a rack, or need one. They will last longer if you keep the fluid changed.
Every other rear I replace the springs. Not from wear, but because they will crack. (I've never seen that on any of my road vehicles). The hinges on the rear lift gate break every couple years.
Again, I agree that is excessive, what brand are you buying?
I know the little fiberglass frame under the windows crack all the time. Are you talking about that or the actual metal structure of the lift gate?
There was a recall on the hinges and bolts for that body (I don't know if that specific year was involved) that was supposed to eliminate cracking of the glass and trim work.
Have you ever had it to a professional to get that looked at?
Burning or leaking?
Have you considered that the wiring or module may be at fault and not the sensor that never seems to fix the problem? All that stuff routes through the GEM module, which is supposed to include a time-delay battery saver relay that will time everything out after 5 or 10 minutes anyway. Sounds more like GEM issues than door sensor issues to me.
:temper::pissedoff:
They are somewhat more delicate than previous versions. I don't care for them myself. Large, bulky, unwieldy, delicate suspensions, and not much to look at either.
since 2004. Bought it used with less than 30k miles.
Replaced solenoid. Also had to replace a servo piston.
Started with duralast and that is when I was replacing them twice a year. Switched to Timken (always had good luck on everything else with timken-atvs, cars etc) which got me down to replacing them once a year.
Ya, not really so much a surprise as just a lot bigger undertaking then I wanted for a weekday evening. My wife needs it for school tues/thurs. I was hoping to just be a ball joint...
First couple times I stuck with motorcraft. But at the price/frequency I had to replace them, I became a JY parts collector.
When the fiberglass frame cracked, I just accepted it. But the metal structure of the lift gate near the corner actually appears to have fractured. There is a hairline crack on the outside/inside that shows through the paint.
I'll look into the recall, cause it is time to replace them again. First time it broke I was at a compusa store. They were having a store closeout so I stocked up on a bunch of gear for a few of my IT accounts. Went to put about 5k worth of computer gear in the back of the car and the window fell off. Of course it was pouring rain....:yahoo:
Yep. This vehicle made me lose faith in my mechanic skills ( I worked at a transmission repair shop for a while, so I at least have an idea on which end of the wrench to hold- most of the time :D). I have spent several thousand dollars (close to 10k in shop bills, not counting the parts I've done myself) in repair bills at different shops thinking maybe I was installing the bearings incorrectly. (not seating them correctly or overtorquing it) but the repair schedule seems to be about the same.
Burning or leaking?
I have always assumed burning. I have seen random small spots of fluid on the driveway recently, hadn't been able to determine what it was. Now I know it was from the rack. Now, it could be leaking while driving, but I have not found any trace.
Never thought of that! Thanks for the idea! Now that you mention it, it used to shut off after ~10 minutes but hasn't for a few years.
I agree. Wife loved it though. It's an EB. She decided at the time that an expedition was just too large and we needed the third row. (I have 4 kids).
Well, I just pulled out my file on the car and started looking at costs. So, at 8 years of ownership, I'm over 24k in repair costs. I think I paid ~20k for the vehicle.
Sounds like the trade-in light is on.
Must have been built on a Monday or a Friday. The wife has an 03 with a 4.6 and 180,000 on it and have only done a transmission rebuild (at 90,000) all wheel bearings and the timing chain and guides. Had it since 04 bought it with 30,000. Still going strong with no intentions of trading.
Quit yer braggin...
Every time I think of trading it in, I look at the price for something else and the payment comes out higher than my repair costs averaged over 12 months. So, I suck it up and fix it. So, in 6 months when I have to tear into it again, I'll be all pissed off again. I was offered $1500 on trade at two different dealerships. (because of all these issues.)
There is a good chance that the next time it breaks down, the seats are going in my ranger and the 4.6 will find a new home as well. Then I'll take a can of gas and a match to it...
Quit yer braggin...
I'm not bragging...cause if I started everything would go wrong with it. It is different to hear others saying what a problem they have had with vehicles and others saying they have had no problems at all.
might come out as more money, but is it not worth it so you don't have to constantly work on stuff? something is wrong with that thing... or maybe its just the repairs (I'm not doubting you, but something is fishy)
