- Feb 24, 2011
- Huntsville, AL
- Total Lift
- 3 Inches
- Tire Size
- 33X11.5X16 (285/75R16)
I finally came across a '00 Mountaineer for really cheap, and I will most likely be buying it or ending up with it for free depending on how things play out. So I will be transplanting the mountaineer's powertrain into my '00 Ranger, hopefully towards the end of the year.
I am going to find an m5od-r2 4X4 tranny to use (my truck is already a 5 speed, 3.0L, 4X4).
From what I gather I will need the following in order to make everything work:
1. m50dr-2 from '97-'03 F-150
2. 11" clutch, pressure plate, block plate, 164 tooth 50 oz. flywheel, and manual starter from '96 F-150
3. And either an adapter for my BW1354 or upgrade to the BW4406. I don't think the BW4406 will fit, especially since my truck is a regular cab and my current transfer case sits about six inches from the gas tank as it is.
I've heard that I can reuse the clutch slave cylinder I already have since the F-150 has the same part number. But can I also reuse my master cylinder and clutch cable, or will I have to upgrade those as well?
Also, will the 5.0 radiator fit in the ranger? My truck is the same year as the donor vehicle so I am hoping it's at least close to a direct bolt in....
If this all works out you all can count on a THOROUGH build thread in the future, as I like to document projects like this for future reference.
