- May 24, 2011
Hey guys got a Bronco II with the "CURSE"...the symptoms: Starts up idle for about 2-3 minutes then dies, sometimes it dies rough other times not so bad.
Has new: In tank fuel pump, high pressure pump in rail, fuel filter, inline fuel rail filter, IAC valve, TFI module, TPS sensor, MAP sensor.
I have 2 bronco ii's so i have been swapping parts between the both of them to find the culprit, one is an 88 and the non running is an 87, both 5spds with 4wd. Swapped the ECM module but didn't help so i'm assuming the ECM is good. I think it could be a bad ground somewhere but i cannot find it. There is a orange wire (ground) that runs from the ECM to the back of the block that i thought was the problem but it is not.
Any ideas would help greatly...thanks.
