94 Explorer Starting Issue
84bluebronco2
Central New York
Having a bit of an electrical issue with my 94 Explorer XLT. Went to leave a friend's house two mornings ago, and no start when I turn the key...
4.0 M5OD 4x4
So far I believe I have eliminated solenoid, battery, and starter issues. I can jump the solenoid with a screwdriver to get her to fire up, and I can jump to the top post of the solenoid from the positive terminal on my battery and she'll fire up.
That leaves me a bit stumped... Any one have a wiring diagram clutch safety switch, and the ignition?
I'll give the search bar a shot in the meantime.
Thanks Everyone.
In 93 (Ranger) the clutch switch wires for the starter solenoid coil were Red with a light blue stripe (R/LB) and PK (pink). Short those two wires at the clutch switch connector and see if it cranks!
I noticed that when I was checking around with my multi meter. What might the four other wires be though? lol
Today I got at my starting problem again, and jumped the wires for the clutch switch, but still no dice... That would leave me thinking that the problem is in the wiring between the ignition cylinder and relay under the hood...? Any ideas?
Wiggle the small guage wire on the starter. When I had my 94 that would work loose every once in a while, maybe yours is doing the same.
It starts with no problem if I jump the solenoid, or run a jumper from the battery to the post on the solenoid. I'm fairly certain that my wiring is good between those two components.
Ok then......get a test light. See if the small wire that fits over the post on the solenoid under the hood is getting power from the ignition switch. You may have a bad ignition switch or broken wire between the ign. switch and the under hood solenoid.
That's what I figured to do, but need to find some longer leads for my multimeter.... Sucks working alone sometimes lol.
Get someone to help you.
Got the truck to start with the key again.
I ended up going under the dash and finding this... :icon_confused:
<a href="http://s1162.photobucket.com/albums/q539/84bluebronco2/?action=view&current=1342771642206.jpg" target="_blank"><img src="http://i1162.photobucket.com/albums/q539/84bluebronco2/1342771642206.jpg" border="0" alt="Mysterious device in my harness..., Some weird harness and plug with a relay attached..."></a>
It had strange plug on it...
<a href="http://s1162.photobucket.com/albums/q539/84bluebronco2/?action=view&current=1342771642522.jpg" target="_blank"><img src="http://i1162.photobucket.com/albums/q539/84bluebronco2/1342771642522.jpg" border="0" alt="End of mysterious device., This is the plug on the end. 4 of the wires coming from this plug were spliced together."></a>
Proceeded to remove from the middle of the red/lt blue wire.
<a href="http://s1162.photobucket.com/albums/q539/84bluebronco2/?action=view&current=1342771642797.jpg" target="_blank"><img src="http://i1162.photobucket.com/albums/q539/84bluebronco2/1342771642797.jpg" border="0" alt="Device removed., Much cleaner under my dash. Messy wiring frustrates me."></a>
Spliced up, and she runs.
<a href="http://s1162.photobucket.com/albums/q539/84bluebronco2/?action=view&current=1342771643126.jpg" target="_blank"><img src="http://i1162.photobucket.com/albums/q539/84bluebronco2/1342771643126.jpg" border="0" alt="Spliced, and she is good to go., 4 butt splices and couple inches of recycled 16ga wire, and my truck starts."></a>
Thanks for the ideas everyone. :yahoo:
I remember those "anti-theft" devices. They are good when they work correctly but can be a pain (as you found out) when it fails.
That's what my neighbor and I had guessed the device was upon removal. I never knew it was there in the last 2 and half years lol :icon_twisted:
Thanks for the help Explorin. Rep to you buddy.
