kunar
⭐Supporting Member
- Jun 10, 2003
- Toledo
- State - Country
- OH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
so i bought a used set of bushwacker cut out flares and didnt realize at the time that they were in pretty rough shape. a lot of the mounting holes were cracked or pulled through and there was another spot that had a crack probably 3-4" long. here's how i decided to fix them.
the first thing i had to do was figure out what glue i could use on these flares. turns out they are made from ABS which is a plastic thats pretty easy to solvent weld. you can buy solvent made for abs in a can at your local hardware store. its similar to pvc cement or sometimes made to do both jobs. the next challenge was what material would i use to reinforce what's there. a 1/4" washer fit in each of the "pockets" just right, but they only way i could find abs washers they were about a buck a piece. 10 holes per flare puts me at 40 per set and i wanted to do 3 sets. a buck a piece was not an option. i decided i had to make my own and luckily i had some abs sheet laying around. i tired a 7/8 hole saw which left me a plug about 3/4 od and 1/4 id, but they were too tough to dig out of the hole saw and the edges were rough. making 100+ this way would be tough. my dad came up with the idea of modifying a spade bit and ground one himself to do what i needed it too. this worked out great. i started out running these on the drill press but having to start and stop every time to pull the plug out was a real PITA. ended up deciding to use a cordless drill so it was easier to start/stop
after running about 130 pieces (like i said i wanted enough for 3 full sets) i threaded them all on a 1/4" bolt, chucked up the bolt in my drill and spun them on a belt sander. it didnt take much to knock the little burs off of the outside.
to be continued...
to be continued...
