7 ft. bed filler neck vs. 6 ft. bed filler neck
7339
10+ Year Member
So double checked my order, and I looks like I mistakenly purchased the fuel filler neck for a 6 foot styleside, my truck is a 7 foot styleside.
What are the differences in the filler necks?
I believe it is the same part, but I'm not 100% sure.
The opening on the 7ft bed is in the same spot on the bed as a 6ft bed.
My truck has the optional "extended range" tank. (aprox 21 gal).
6ft filler neck
Late update, but I installed the 6 foot filler neck on my 7 foot bed and it is 100% compatible. Filler necks listed for 6 foot bed Rangers are the exact same part as the ones listed for 7 foot beds, do not be fooled.
Word to the wise for those replacing filler necks, save yourself so much time and hassle and remove your bed. The bolts are Torx T-55 and located on the floor of the bed, be prepared to do battle with a breaker bar or a 1/2 drive ratchet with a decently long cheater pipe. I personally used a standard 3/8 drive ratchet with no problems (California truck :yahoo:). Oddly enough, I was also the first person to remove the bed, your results may vary! :dunno:
I did my 97 a few weeks ago. +1 on removing the bed. It took me longer to remove my bedliner to get to the bed bolts than it did to remove the actual bed.
AJ
Sent from my DROIDX using Tapatalk 2
