- Dec 6, 2008
- Age
- 38
- Livonia, Mi
Come to find out, the bolt for my crosspin was already slightly stripped out, and I finished it off and wasn't able to get the mini spool in. Oh well.
I'm just going to buy my dads old axle that has 4.56 gears, lockrite, and disk brakes.
Me and the group at Bundy Hill.
Click the pictures to make it bigger
Everything was going fine till I decided to go play in the mud a little, I was having a little too much fun and getting airborne in the mud.. Then I sunk it in buck lake by accident.
I had to change the oil before I left, the seafoam was put in the crank case to help remove any leftover water.
The engine seems to be fine.
I got home and power washed the truck the next day, pretty much everywhere, even the engine bay (on low pressure).
Later that day the truck randomly died, I assumed it was the starter because the truck completely went dead when I turned the key over, but the battery had somewhat of a charge.
After having a police officer push start my truck with his car.. He floored it and my wheel was slightly turned, it took everything I had to turn the wheel to avoid a telephone pole that was right in the way.
The next day, I took the starter out and it tested fine.
At this point, I moved on to the alternator.
As soon as I unhooked all of the wires from it, the lights inside of the truck came on.
Hopefully Advance auto will warranty it.
All clean. You can see where I slide down very steep/narrow hill and ended up messing up my bedside pretty bad.
escort_gts took these pictures.
