- Oct 10, 2010
1994 Ranger (ish) 4.0, 5 gear, 1350/1354 doubler, 60/14 Bolt on 37’s.
About every 3,000-4,000 miles, the ¼-20 socket head cap screws that hold the two adapter plates together like to loosen up and allow all the fluid in the crawl box to dump out. The first time this happened, a 600 mile u-haul ride home was required to rescue the truck. The second time (this past weekend) I was able to limp the truck home, though it still caused damage to the crawl box.
I am uncertain if I used lock-tite the first time that I put the thing together (too many beers I guess), so that would explain the first failure. The second failure, the thing defiantly had lock-tite put on it. Both times I used the Ultra Grey RTV with no noticeable leaks until the cases worked themselves loose.
There is no noticeable damage to either the cap screws or the aluminum plate that they bolt too. Also, I am not using any extra mounts to hold up the doubler (factory type transmission mount, and stock motor mounts) that could cause some weird stress to the cases.
I’m not sure where to go from here to keep this from happening again, but I do know that I'm getting tired of fighting this problem. I am not finding many other posts about this type of issue (the closest one being what 4x4junkie mentioned).
Any ideas would be appreciated.
