From the outside, they're the same. Inside, the 87 has a thinner wall..
from the back... 58 mm - 50 mm
What is the relevance?
http://www.therangerstation.com/tech_library/Kunz_Korner.htm
"Next on induction if the throttle body, this is a relatively simple choice, the ones on the 86-87 2.9's are much larger and basically your only bolt on piece and tend to increase power in the 3k and up range, without one of these I would find it very difficult to make much power normally aspirated, so I would include this on the must have list."
I posted those pics because I had a hard time finding a straight comparison when I was looking for one.. it's a simple mod, bolts right up.
Agreed, I was looking for some pics before I did my swap and couldn't find a good comparison photo. Thank you for sharing.![]()
...use the larger TB with the 1988-up TP sensor on an 88-up 2.9 engine...
Runnig the SAME ammount of air into a 1988-92 2.9 while the computer THINKS the engine is getting
whatever ammount of air the smaller TB would deliver at 3/4-7/8, this keeps the management system
in "closed loop" and running relatively more lean.
...The real secret is to NEVER give the computer a Full throttle signal from the TPS.
AD
