project family wheeler. chop top 1 ton explorer.
also the lower you can go, and the slower crawl you can get, the better, that way you don't need a camera person, you can put it low low, and then get out and take your own pictures as it crawls up the rocks and trails by it self.
Robert
sent from a computer located in the USA.
I have the clutch, flywheel, and slave removed if you need it. Still have to get the pedals and master out, but should only take about 30 min to do.
No problem fawker. Hope there is motivation now. I made him clean the garage before we worked on it. Kid had piles of shit layin everywhere.
Dustin I could use it if your getting rid of it, did you get an auto pedal assy yet? Still have mine to pull if you haven't.
Fawker you made me clean the garage and around the garage lol, OCD!
I picked up an auto brake pedal. I think I need an auto starter too so my manual one will also be coming out.
I'll have to find my starter, I couldn't find it the other day. I've got a feeling it's sitting in the bottom of my scrap bin accodently.
Got the a/c box off last night and got the firewall clearanced and welded the seam back in where I trimmed it.
Anybody seen any non AC box's around ?
Why not just put a flat plate over it ?
SVT
Does the heat need the hole towards the engine? Wasn't sure if the non ac box's used that hole or if it just blocks it off.
I believe it just blocks it off, but I could be wrong on that...
SVT
Look at the one they did on trucks. They cut the a/c section off and flat platted it
Slo-Vo might want some heat come this winter.
Robert
sent from a wet rock while watch "The Simpsons".
Gotta have heat, during the summer the only piece of glass will be the windshield so it won't be bad.
I thought they kept the heater
