- Apr 20, 2008
- Age
- 47
Hello all!  I've been lurking about trying to find an answer to my problem for a while, but to no avail.  I apologize for the long post, but I'm at my wit's end.
Anyway, here's the deal: I have a 2000 4.0L 4WD Ranger. For the past couple of years, about every 6 months I would start to get a misfire. I would change the plugs and the problem disappeared. The strange thing is that the driver's side plugs (cyl 4, 5, & 6) would be fouled far worse than the rest of the plugs. Cyl 5 would just have carbon and a little oil on the outside, but cyl 4 and cyl 6 would have oil and carbon and oil on the outside. Cyl 3 would have some oil on the outside and would occasionally be fouled by some oil/carbon. Cyl 1 and 2 would be clean as a whistle.
I had read about the MAF and intake manifold bolts here on the site, but never got around to dealing with them. Finally, about a month ago, the MAF starts sending codes to the computer. I tried cleaning, but that didn't work, so I got a new one (rebuild from Advance), replaced it Monday, and I thought the problem was solved.
Within 20 miles after replacing the MAF, I start getting the misfire again (it's been a little while since my last plug replacement), so I pulled over and replaced the plugs. I continued on my trip (~750 miles round trip) and I'm getting terrible gas mileage the whole time. At first I thought it was just the strong wind, but when I started getting less than 10-11mpg, I started to get irritated. I made it back home, but the misfires started up again Friday. So, it's been only about 800 miles since the change.
For the record, I seem to get the best mileage and durability with the NGK iridium plugs, but I decided to try Motorcraft this time. I got the firewire platinum plugs for this change.
I had kept the old plugs (they weren't that old and didn't look that bad), so I cleaned them with carb cleaner and reinstalled them. The truck runs smooth now, but I haven't driven it down the road yet.
So, here are my questions: 1/ Does it sound like I need to torque down the lower intake manifold bolts to solve my problem? 2/ Is the rebuilt MAF sensor I got from Advance crap and I should have got a "new" one instead? 3/ Is it something completely different?
Thanks for any help you can give me!!
Cheers,
Aaron
Cheers,
Aaron
	 Welcome Visitor! Please take a few seconds and
