PetesPonies
2 gallons??? whoa partner, you could paint both with that much paint. What equipment are you using? Serious, 1 gallon would paint the BII with plenty left over.
I'd run the automatic. The C5 is a great transmission and even better with C4 internals. You (probably) have an FM145 or FM146 in the '88...the chances of it being worn out or close to it are fairly good. They are not the greatest. I pulled a good FM145 from my '86 and put in on craigslist, and had ten calls within a day from people trying to revive their old RBV.
It's a C5 (which is almost identical to a C4.) C3's and C4's were never offered in RBVs.
Yes, you can use the computer for the '88. Speed density ECMs do not care what transmission you have behind the engine. I am using the ECM from a Crown Vic which had an AOD and I have a 4 speed NP435 manual in my truck... works great. You will just have to fabricate a kickdown cable/rod, but that is a very small price to pay to have a nice transmission.
No you'll need to make the kickdown rod/cable if you put the 2.9 in. That will allow the automatic to shift down into first when you come to a stop. People have put C5's behind 4.0s, it is doable.
The big problem with the FM transmissions is that they are not very strong, the shifter bushing breaks off and is impossible to replace (leaving you with a very sloppy shifter that won't let you shift into some gears all the way) and the input shaft bearings fail rather quickly.
if you look at the tech page on the rangerstation you can find most of the info you will need to do your swap. I just transplanted a 92 explorer 4.0 into my 88 ranger after rebuilding the motor. I took infomation from all the post listed in the tech pages along with a shop manuel. I haven't finished every thing yet but the motor runs good. just got the new exhaust to finish up and some body work that happened from a storm we had. I will be posting pic of the whole swap once i finish everything. Thanks to all the guys that posted info on their swaps.
i thought the 2.8 and the 2.9 have the same bellhousing, the C5 is from a 2.8? explain please.
They do, and so does the 4.0. The bellhousing bolt pattern is the same on all three. What I am saying is that you will need to build a kickdown rod or cable (it is a metal tube that goes from the carburetor to the shift linkage on the trans) because the 2.9's throttle body is in a different spot. Automatic transmissions will not downshift correctly or at all if you don't have the kickdown set up correctly.
It's worth investing in a HVLP setup. I do everything you mentioned with less than a gallon on an avergae car. I painted a Lincoln, no jambs, with 1/2 gallon. No use throwing all the painted into the air.
im using a HPLV sprayer.
