Is a solid axle swap possible, while maintaining a OEM ride height (and rims and tires). Every SAS I've seen seems to lift the truck up several inches, curious if the OEM look is possible.
If $$ is no object i believe you could get close. Not sure how big a D-30 is compared to a D-44 but my 44 was very close to hitting my engine crossmember, verrrrry close and I cut ALOT of it away.
I think if you rebuilt the engine x-member, you got a chance of getting close.
Discuss:
Why would you want to SAS just to run stock tire size?
Todd S.
Fuel economy and a D-30 has a nice selection of aftermarket locking difs. The little 2.3 is doing me great on fuel.
I'm most likely just going to swap in a D35TTB. I was wondering on a scale of 1-10 how hard this would be. 1 being easy, 10 being impossible. It sounds like a 9. If it was a 2-3 area I'd think about it. I had no idea.
You'd get WORSE gas mileage with the D30 vs the D44 due to the hub assembly setup. You cant unlock/lock your hubs.
Why the stock height tho? Most ppl swap to the straight axle for strength/flex while offroading, hence the lift. What do you plan to do w/ the truck?
I dunno about you guys, but I use 4x4 for in the snow and stuff, not rock crawling, so I could stand a stock height 4x4 with solid axles..... the Cherokee never got stuck![]()
So you have a 2WD now and want to go 4x4? Even factory 4x4's like mine have a lift block in the rear to compensate for the added height of an axle under the engine.
My understanding was if I got a Dana 30 I could just build it up. Convert it to locking hubs, put the 4.10s in it, locker, etc. Kind of the route I'll probably end up taking with a D35TTB.
You'll have about 3,000 bucks in that D30 to get it to where it would make you happy (gears, lockers, hub kit, etc.)
So for some the D30 may give you worse mileage, for others like me, it did nothing.
A lot less than that. If you feel like driving I have a complete Dana 35 in my yard minus the radius arms I'll give you for $100. You'd have around $500 in regearing it and another $100 or so in getting lockouts for it.
Why are you saying $3k into a D30 it will have stock tires on it. So the stock shafts with 297x joints is plenty strong, the cv style even stronger. A spartan runs around $300 make sure to get one with matching gears in it 3.27-4.10s are all common. Build a set of long arms off the tranny xmember and run a y-link, V8 ZJ tierod, 3-5" xj coils depending on the coil bucket height and JK shocks. You could easily get a D30 under a ranger for $1500 as long as you can find the right parts, and know your way around a welder.
The unit bearing hubs also barely affect gas mileage ask anyone with a new ford, chevy, dodge, jeep, toyota, honda, suzuki, hyundai hell any new vehicle all current part/full time 4WD and AWD vehicles utilize unit bearing hubs and live axles that means the whole shebang is always spinning. If it was destroying gas mileage they probably wouldn't be using them. Its also kind of nice to not have to get out and flip into 4WD when the fronts buried. Not to mention they are stronger.
On the OPs question a D30HP can be installed at the stock ride height. It is smaller than a D35 hence if the D35 clears a D30 will.
