- Mar 7, 2012
- Williston, ND
what is the carb exactly? you said 2100 motorcraft carb what should i look for ?
It must be a 1.08 or smaller venturi size anything larger will never dial in correct!
what does the 2bbl refer to?
These following numbers are for AUTOLITE/MOTORCRAFT 2100 Series Carburetors. This number can be found on the left side of the float bowl, right behind the accelerator pump rod, inside of a circle. The number(s) on the left corresponds with the CFM rating(s) on the right. The first numbers are the Venturi Size, the second is the corresponding CFM.
These numbers are for 2V carburetors only (2100/2150).
Number = CFM
.98 = 190
1.01 = 240
1.02 = 245
1.08 = 287
1.14 = 300
1.21 = 351
1.23 = 356
1.33 = 424
These numbers are for 4V carburetors only (4100)
Number = CFM
1.08= 480cfm
1.12= 600cfm
1.19= 670cfm.
(1.19 Used one year only. 1958 MERC 383 HI-TORQUE ENGINE-Very Rare)
Thanks if it made sense and was 2 brl or something along those lines i wouldve got it but i just dont get why theres 2 b's lolBBL is the crappy abbreviation that the automotive world came up with for "barrel".
Thus you need a two barrel carb, one that has the throat split into 2 sections while you look down it.
thanks a lot definitely printing that pageHere's some info that may help.
It doesn't convert exactly to automotive terms, because BBL is for a barrel of something, liquid or solids.
