- Jul 23, 2011
- Age
- 72
- Indiana
Did the duraspark conversion with help from some members here
Ran fine and when I went to start it today it had no fire. Coil??
Did you use the stock coil if not put it in and see if it works.
Coils VERY rarely go bad . . certainly not overnight.Just go back and check your connections closely. Check for continuity through all wire connections. How long ago did you convert and how much was it driven?
Did you use the GM HEI module or a Duraspark box?? You should check all connections like I said, but also check the operation of the pickup in the distributor. It's easy to do and info is here or anywhere on the web to tell you how. If you used the GM HEI module, there is a simple troubleshooting sequence for it as well.
