- Aug 21, 2007
I have the 1350, and my donor rig has a 1354... but its an electro shift, can i still use it for the doubler?
you would have to use the 1354 as the t-case and the 1350 as the doubler. the part of the case you throw away when you turn it into a doubler is the part that holds the 1354's electric motor and shift linkage.
using the e-case as the rear case means all you need to do is stretch the wires into place, then you can use a stock manual t-case shifter to shift the doubler case.
