I have the Ford 8.8 28 spline LS, worth upgrading to 31 spline?
nooch450
New Jersey
I have the stock Ford 8.8 28 Spline LS rear in my truck, I want to run 4.56 and an Auburn Electric Locker... It it worth putting into this axle or should i try to find a 31 Spline Axle?
Id rather reuse mine unless there is a good reason somebody wants to talk me out of building the guts of the 28 spline with a locker n gears...
Basically, is it worth finding a new axle (31 spline)? Or is mine strong enough...
The auburn is a pile of ****ing dogshit. I wouldn't build a 28 spline it has same bearing and shafts as the 7.5"
It all depends on what you will be doing with your truck. Hard core wheeling, then I would upgrade to a 31 spline or bigger. If just normal driving and some wheeling then the 28 will be fine. I have the 28 spline with a lock-rite and no problems yet. But mine is a daily driver with some weekend wheeling. Nothing hardcore.
Sent from my PC36100 using Tapatalk 2
I had a locked 28 Spline, less than 2 weeks later I broke a shaft doing a doughnut...
SVT
Either way you go the auburn is still garbage. I would rather have an open than use that POS.
OK it looks like the 31 spline upgrade is nessasary... Im guna be rough on it... I chose that locker for the price and the fact that it has limited slip while dissengaged. What lockers are best for price, NO AUTO, i just dont like the idea...
I heard 95 and up explorer is best...I can get an Explorer 8.8 31 spline for a junk yard for $300, they will pull it. Does that price sound high?
I can pull one here for $100. I'd be leery of someone else putting it in though. Especially from a junk yard.
But yes, 95+ expo axle. They come with disc brakes.
I suggest an ARB air locker. Price is kinda high but well worth it.
There is a reason that the Auborn is cheaper. You will be replacing that locker if you want something that actually locks up with a wheel in the air. I have wheeled with plenty of Jeeps running those POS's and every single one of them does not lock up anymore. Do your self a favor and pay for the quality of a real locker. Eaton E-Locker, Yukon Zip locker or ARB if you want a selectable. Otherwise a Detroit, grizzly something along those lines will work. There is nothing wrong with auto lockers a lot of people run them with tons less issues than that shit auborn.
I can pull expo rears for $100 as well $300 is a lot.
I can probably ship you an ex 8.8 for less than 300, that includes the price if the axle...where you located?
SVT
I bought a 31 spline 8.8 from a 1996 explorer for $200. It has stronger axle shafts and disk brakes. If you find a good deal on one I would go for it. This way you can set up the gears while still keeping your truck on the road. Good luck man!
Im in new jersey...
Thanks for the help guys, the yards around here give $300-$400 for a scrap car / truck. Than the J/O wana sell me just the rear for $300!
Do some shopping before you buy one for $300. I know 2 jy across the street from each other. One tried to sell a friend of mine a 14 bolt for $500, the other one is $50 any axle you pull it.
Sent from road while ignoring traffic
I agree about the Auburn, I've seen those things in action several times myself.
In spite of marketing claims saying otherwise, the ECTED is NOT a locker at all (there are no locking pins, splined engagement gear or anything of the sort inside it). It's a limited slip diff that simply tightens up it's clutches when you "engage" it. Even when brand new they don't "lock up" well.
If you want a locker, the ARB or Yukon ZIP is what you're after.
