- Mar 16, 2012
I have a 97 ranger 4.0 5 speed 4 wheel drive and I heard that when it's in 4 wheel drive both tires don't turn? Is this true?
If I'm stuck in mud shouldn't both tired in the front be spinning? Maybe I need to educate myself a little more about this lol
How can I check if I have a open diff
Also make sure the trans is in Neutral if you do this, otherwise you can still force a limited slip (posi) diff to turn the wheel in the opposite direction.Jack up the truck so both tires on the axle are in this air, spin one tire, if the other tire spins the opposite direction its an open dif, if they spin the same direction its got a posi. Or just read the tag on the diff. It if reads 37321LS its a 3.73 Limited Slip.
sent by another dumbass using Tapatalk.
