Newbie here with questions...
87B-II
10+ Year Member
Galena, MO
ok so i have a Bronco II that i've been building on for a few years now...
Current build is:
1987 EB Bronco II
James Duff 5 1/2 - 6 " stage three suspension
5" body lift
Cut out fender flares
91' explorer axles/trans case/dash
33" good years on MT classic lock II wheels
5.0 HO w/AOD advanced adapt to maintain stock transcase location
warn 9500 patriot wench
Currently considering:
SAS
or TTB 50
and going with sterling 10.5 rear
The reason for the sas consideration is that I was given the axles from a 1999 F250 SD. Which i graciously(sp) accepted. When Ii removed the axles I took everything that was attached to the frame hanging down, I also removed the hydraluic brake master cyclinder (could come in handy). If I do the SAS was wondering about coils vs leaf? Any suggestions, comments or advice would be greatly appreciated.
Thanks,
Sean
Why such the big body lift???
Coils are good for ride, leaves are good for stability. But you will have to ditch that body lift, no blocks on the front axle.
