Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
I have been debating over trying it myself or having it done since I put Explorer coils in the front. Since the local dealer charges $60 to check caster and toe (or something like that) and then $80/hr to do anything after that I figured I might as well get everything broke loose, put the bushings and outer TRE's in and give it a whirl aligning it.
Read the article in the library here: http://www.therangerstation.com/Magazine/winter2008/steering_tech.htm and I have a few questions.
Using the rods to relieve tension in the suspension makes sense, I have an weighted magnetic angle finder guage that I got for my rear axle swap. There is no floor I have available that is level though... it is pretty close but after 30-40+ years things settle. Is that going to be throwing things off? How do you work around that, shim the whole truck so it is level? (if so level to where, while a nominal brick there isn't much that is really much level to anything)
Is a caster/camber tool worth getting? If so what is a good one for maybe one or two alignments per decade?
