 - Dec 4, 2010
- Age
 - 58
 - Cherry Hill, NJ
How can you tell the difference between the two motors visually?
If they both fit, they both fit. Generally the larger filter is better, but really a fresh filter at all is good.
I've always been under the impression the 2.3L and 2.5L are externally identical. Though since the 2.5L's are the newest of the Lima blocks, there may be a rib or two different, if anything, for NVH, as that became an increasingly important issue.
Apart from the crank, rods, pistons, they're the same engine block (dimensionally). I do believe the heads are also juuuuuust slightly different somehow. Exhaust ports/combustion chambers come to mind.
http://www.therangerstation.com/Magazine/Spring2003/4cyilinderoilfilter.htm
Take note of the 2nd paragraph.
And it'll fit, I've put an even larger one on my 2.3L 4 banger before. Bumped the oil capacity to just over 6 quarts.
In the first picture (the two filters side by side) The one on the left is what my truck "calls for" but the one on the right is what is actually on my truck. I really do not care if I have either motor, I just want to make sure if something needs to be replaced I get the right part for the right motor. So far I have replaced the starter, the alternator, the solenoid and have told them it is a 2.3....everything works.
well i have a 2.5l sitting out on my trailer right now that i could take a look at and a 2.3l in my truck.
i did notice that the 2.5l has a "25" on the side of the block but i have not looked at my 2.3l so i can't tell you if thats an identifying mark
Yes, "25L" is cast on the passenger side near the bell housing behind the exhaust manifold.
The attached pic is from a 2000 Ranger 2wd. Notice just behind the O2 sensor wiring.
