- Nov 24, 2009
I have a 1994 Ford Ranger 2.3l Rwd extended cab a few weeks ago it was running fine when i noticed a puddle under the passenger side rear tire. I found that the bearing had broke and pushed out the seal in the axle. I finally had the money to fix it and i fixed that and replaced the brakes (only rear brakes) and i went ahead and replaced the valve cover gasket went to fire it up and it was idling really funny kinda like a v8 does when it has a big cam then when i went to hit the brakes they went straight to the floor. i pumped them a few times then they would get hard while i was pumping them and once i stopped and did it again right back to the floor. When the brake pedal hits the floor the truck almost completely stalls out? Anyone know what could cause this? Thanks in advance for the help.
