2" Body Lift
morbert
10+ Year Member
Looking to do a 2" body lift on my 89 Ranger extened cab. This is my only driver so I want to make sure I have all of tne parts. How many bolts and what size length do I need to buy? Can any of the original bolts be used? How many blocks and washers? I plan to do this in a weekend so a complete parts list would great. Thanks in advance to all help......:
I'm not sure off hand how many bolts/washers/nuts/blocks are needed but if you look at http://www.performanceaccessories.com/, they list 2" body lift (part number 832)for your application and show pictures of the kit. Look at the picture and it should at least give you an idea how many of each are required. If you download the manual it lists the bolts required. If you want to just buy the whole kit, summitracing.com is one place I know of that sells it.
^^^what he said. I only used PA bl kits and I have done all my Rangers and BII's and never had any issues. You get everything you need. The kits come with bumper brackets to raise the bumper (certain years will not come with the bumper brackets for the front or rear). When you look online the information is all there of what you get in the kit.
Good luck.
