- May 17, 2009
I have a 91 ranger that i've built into a mild prerunner style truck. The beams are 3 inches over stock and bent to compensate for the 5.5 springs that it has. I have a skyjacker drop pitman arm, not the extreme one, but the one thats about 3 inches drop. I extended the steering for the beams, so it is also 3 inches over stock.
I'm having bump steer problems.
Now I expected a bit of bump steer, but not this much. Not to mention the massive toe in I get when cycling. I'm looking to pick up ruff stuff specialites crossover steering kit with one ton TRE's if that will help my problem. It seems that it will because it lessens angles the steering has. I'd build a swingset style steering but I don't really want to run hiems in my steering because this is a dd.
This is the steering I am looking at:
http://www.ruffstuffspecialties.com/catalog/YLINK.html
This is my truck
Here you can see the toe im getting, I don't mind this so much as I do when I'm driving it on the highway and it darts around.
Thanks for any input you can provide. I know whats involved in installing this kit, and understand that that beams have this problem without swingset steering, but I'm looking to minimize the bumpe steer as much as possible without the use of hiems.
This is my truck
