Hello,
I recently bought a 99 ford ranger "off road". It has a 4.0 V6, which is a nice engine to have for the size of the truck. 5 speed manual tranny and 4x4.
Truck has 135k on it. After I bought it I replaced the clutch, slave and throughout bearing. Updated all the regular maintenance.
Question 1: Vibration and noise from 4x4.
So, the 4x4 engages and disengages ok from what I can tell. I checked the vacuum lines and they seem ok. When I take it out of 4x4 it seems that there is sometimes more noise and vibrations that before, also the truck seems sluggish as too many parts are turning, or more than before.
It just seems a little strange to me.
Not sure if I have a u-joint bad, bad transfer case, bearing or what.
Question 2:
Hopefully I can explain this correctly. As stated before, I changed the clutch and everything with it. This is a small problem, but it annoys me. When pressing the clutch down, it disengages fully within the first 1/2 of the full clutch petal stroke. after that it is just empty motion. I do not think it has air in the line as it was bled, and it is disengaging fully. is the an adjustment I am missing. It just bothers me when shifting as the comfort of it is not great. The same can be accomplished with much less motion.
Rant: Why in the world would ford put a junk rear end in their so called "off road" 4x4 model. The one wheel peel during the snow is horrible. The truck is much better suited for a limited slip. Even with 400 lbs in back it does not matter. It sucks even with an inch of snow. I would think I should be able to go through something without 4wd. First Ranger I have owned with 4wd and not very impressed. -- sorry just had to rant.
thanks for any help.
Question 2:
