- Nov 9, 2008
- Windsor, Colorado
What does one need to convert to rear disc brakes? Will it work with stock alloy wheels?
I didn't put a proportioning valve in the vacuum booster is upgraded to a double diaphragm from a early 90's explorer that's my only other mod.I think it would stop better than say a TJ with 33's.
Some of the reasons I didn't go with a explorer axle is the cost by the time I get the 4.10 gearing in and it bought new brakes on it's going to be expensive.As I understand it's about 2" wider than my stock one and I'm close to needing mud flaps now to meet Cali law we've had write ups in the wall street journal how many cops are in my area and desperate to write tickets.
I would rather do this than change the rear by the time you move the spring pads to the top.Which has to be at the proper angle weld in some shock mounts.Plus I don't think my drive line would bolt up.I would have to take a torch and grinder to get rid of the existing hardware.I have the tools a and ability to do these things but I think it's a bigger job.I don't feel I put my rig through the abuse to need the big axle 8.8 If you put in a stroker small block or riding in big rock with big tires it's the only real choice.
As for the gear swap if you already have a 4.10 in your truck just pull it all out. Keep track of your shims and put EXACTLY in the same place in the new axle. The gear swap I did on a different afternoon and still only took me half a day.
Also an 8.8 axle is the same width as a 7.5
And the ranger flange is exactly the same bolt pattern as an explorer
I wanted to add to this thread that the brake article said the anti moan bracket is optional.Mine made some serious noise and I put the anti moan brackets on and it went away.Had to shorten the bracket a little to get it to fit.
