Escorts 2nd SAS
I'm sure you did yours well. Mine is ziptied since I installed it right before the last wheeling trip.
Yes, it is mounted with brackets and is not going anywhere.
Ive only copied you on doing a D30 SAS, and trackbar mount...whats one (or more) thing going to hurt????
Have to say looking nice so far.
You can copy my ideas as much as you want. Some of mine came from others anyways.
Some work done on the bumper. Went to get the tubing, cut it up to the lengths I needed for each piece. Went to my friends that runs a fabrication shop and got to work. Spent most of the time discussing ideas and then started bending.
Here is what was done. The pics suck. Sorry.
Escorts 2nd SAS
Escorts 2nd SAS
Escorts 2nd SAS
My next day off is Wednesday. Hopefully be.able to finish it then.
Good start man, can't wait to see what it looks like after wednesday!
Hopefully more work and less beer, talking and looking at it.
Here is what I got done today...
Cut the coil retainer off the axle...
Escorts 2nd SAS
Escorts 2nd SAS
Then welded this plate to it....
Escorts 2nd SAS
Then welded the coil retainer on top of the plate, it's now centered on the axle...have the shock mount welded on too...
Escorts 2nd SAS
Escorts 2nd SAS
Painted....
Escorts 2nd SAS
All put back in, looks much better now.
Escorts 2nd SAS
Before
Escorts 2nd SAS
After
Escorts 2nd SAS
Only took me 6 hours. Take it for a drive tomorrow and see how it does.
I also welded some skid plates to the lower control arm mount. I'll have to take a pic of it tomorrow
Thanks a lot for this pictures.
This will save me from lots of trouble when i start working on mine, since i have to relocate those coil retainers like 2" closer to the dif pumpkin, and now i know i must center them in order to have the axle centered and to avoid issues with the coils.
Thanks bud. :icon_thumby:
Nice job on the tube. Thats gonna turn out nice.
Did you have to clearance/cut your engine crossmember at all when you did your SAS?
In this truck since it was originally a 2wd. But on the 89 it was already a 4wd that had the cut out for the diff already, didn't need to do any clearancing. But the 89 also had more lift than the 93.
Didn't get anything done today. My friend was busy with other projects. So....tomorrow?
Well, my buddy is just way to busy with other customer project at the moment. So unless I can find someone else that has a tube bender I can use, this won't get done till next week.
Maybe I should just buy my own bender.
dustin uses a HF bender i believe. sure its no JDM2 or j2dm or whatever, but it'll work..
If I was going to use a tube bender a lot, make things like a cage and sliders etc....then I could justify spending the $400+ on a JDM2 bender. But, since I know 2 people that have one, I can just wait to get it done. My brothers friend has one but I dont really know him well enough to go use his stuff.
My buddy has a JDM4 hydraulic bender that's all computerized. Just use Bend tech for the design, put the tube in the bender and just hit enter. It does all the rest. It's a cool setup.
Update:
Finally got time. Friend finally got time so got some work done on the bumper...slowly but surely
Escorts 2nd SAS
Escorts 2nd SAS
Escorts 2nd SAS
Had to stop and pick up my son from school. So this is the stopping point for now.
Escorts 2nd SAS
Escorts 2nd SAS
Escorts 2nd SAS
love it. looks good.
Nice lookin bumper. I'm probably gonna copy it i like the design alot kinda looks like 97trailrigdd's. And i like how you modded your coil buckets with the piece of pipe another thing im probably gonna copy keep up the work everything looks amazing.
