bronco ii sas pan hard bar braket
brando-commando
10+ Year Member
littlerock washington
ok im havin a problem findin away to build or buy a braket for my panhard bar... does any one have an ideas of where i could buy a braket from that would just bolt on... or am i gonna have to fab one up?
Ruff stuff specialties sells a kit for $180 that includes everything to build your own and if you look in the vendor section you might happen upon a nifty discount code
But none of it will just bolt on. It requires fab work/welding.
Fab your own. Made mine use the three bolts that held on steering box. Seems like i notched a heavy wall piece of sq tube, then welded it to a plate that was drilled for the steering box.
Wow!!! 150 frog skins for that bracket!
Im in the wrong business.
thanks alot guy for all the help! definatly gonna come up with somethin... one more question does anyone have any step by step directions or photos of doing a 4.0 swap on a bronco ii i have an 87 and would like to keep the stock dash and gauge cluster but havent found anything on how to do the wiring for keeping the stock gauge cluster??
Nobody has ever done anything like that. There wouldn't even be anything in the tech section. And I'm sure glad trs has no search function.
:D:D
I built a custom one on my F150 back in the day out of plate steel
^To give you an Idea.,
i gladly payed $150 for the track bar bracket.
the only thing they dont tell you is it is made for
hiem joint track bar set up.
so i had them make my track bar to.
if you can make one great, i cant.
i now have eb dana 44 disk brake set up under my bii
