- Jul 9, 2011
- Marshfield MA
- My credo
- to prevent Found On the Road Dead, Fix Or Repair Daily
I know the clutch is bad and needs replacement. I am just commenting on its symptoms. Right now, if I put it in gear after a cold start, I can let the clutch out all the way and it will just sit there. After a 4 count, something takes up and away we go. Reminds me of a Torque flite running a pint low. The clutch engages at the very top, and chatters if you give it too much gas. So I've been thinking about hydraulic clutches. The slave cyl. is like a caliper. A caliper piston can stick. Could a slave cyl. stick?
