So if I'm not an oil field worker it's ok to drive 75mph in 4wd?
So if I'm not an oil field worker it's ok to drive 75mph with the hubs locked and not in 4wd?![]()
I fixed it for you, Pay more attention.![]()
it is common for oil field workers and RR workers to run down the HWY with the hubs locked...... so it is more common for them to have this failure........ why.... you feeling left out?
NOPE. Just funny how different areas of the country think of certain things. Around here that would be loggers and farmers.
So if I'm not an oil field worker it's ok to drive 75mph in 4wd?![]()
Its also very common for their trucks to be neglected (low fluids, worn u-joints, etc).....Unlike the rest of the cars on the road that are actually well taken care of.
i'm guessing it was in 4hi on the highway when that happened.
It's not the transfer case that is the problem. It's the worn out front driveshaft double carden joint that allows the DS to spin at high speed OFF CENTER that eventually destroys the T-case. I've seen many, many of those failures and the drivers that were kinda paying attention at the time say there was a bad vibration just before the explosion.
Or maybe some people need to maintain their rigs.Fact is, no matter the cause, this shouldn't be happening. These trucks say Superduty on the side. Bent Bolt has seen "many, many of these failures" and that sounds like there should be a recall--one that strips off the Superduty badge and replaces it with a wet Kleenex insignia.
Or maybe some people need to maintain their rigs.![]()
