Any help would be greatly appreciated and ill try to respond to questions every night.
i have the same problem
also when my engine is warm the oil pressure drops on idle
All that started after i sunk my car
oilpressure always drops on idle when the engine is warm, the oil is thinner and there's less resistance.
The truck is a 1988 ranger xlt 4x4 2.9l. At least once a day it will randomly start sputtering, like a miss fire, loss alot of power and blow black smoke out the back. i have already done a tune up, plugs, wires, cap&rotor. Also replaced on the truck recently was a distributor, coil, and fuel filter. i've been trying to fix this problem for over a year and with having to do a lot of highway driving for school, the huge loss in power makes it difficult and very annoying.
That's true, but my oil level light comes on
So add some oil.
If your oil level is correct and your oil pressure is correct (do a mechanical pressure test) get it nice and hot, put 5 qts of diesel fuel in the oil, let it set (NOT RUNNING) for a few hours, and then change the oil. Probably crap stuck in the level sensor.
also tested and replaced the o2 sensor just to b safe
did your truck have any codes before you replaced the O2 sensor cause mine has none![]()
