- Jul 17, 2010
My 88 ranger is running rough. one second it is running great then it starts what I would call "missing". I narrowed it down to #4 cylinder by pulling spark plug wires and noticing engine rpm drop on all but #4. I pulled plug and replaced. I replaced wire. I checked fuel injector...seems same as all others. Tried the "Sea Foam" game with vacuum line and full tank. Engine is fresh rebuild with new heads. I really don't think it is a compression issue but I guess it could be. I used new head bolts with new gaskets and correct torque procedure on head, upper/lower intake, etc.
Seems now problem is getting worse. haven't ck to see if spreading to other cylinders. I have read that I need to "check codes" Don't have the code meter and don't really want to buy one. Someone mentioned a check light. I have DC meter.....
Need some direction
Need some direction
