body lift
sloth69mustang
central OH
do they make a 2 inch body lift for 97s? trs only sells 3 inch. and i would rather just have 2 inch. i am trying to keep the center gravity down a little bit but i need the 2 inches to clear a possible 347 swap in the future and/or 36s.
You can look search on google for it or see if 4wheelparts.com has them.
yeah i looked before and didnt have much luck. maybe i will buy the 3 inch and cut it down? hahahaha idk if thats even possible.
Look on Performance Accessories website or on James Duff. Those are the last two places I'd look before making one work.
You can piece together a kit. Summit sells just the individual blocks (2", 3", or 1") and get hardware at a local hardware store.
Are you sure the extension will be needed? Or could you just have a shifter that will be 2" lower?
for the shifter, just take a piece of pipe with a threaded hole and make it as long as you want and set it in place, put a set screw in tapped hole, and put shifter knob on the top
