Drive shaft Question
cwb90
10+ Year Member
2005 Ford Range
I have a 05 ext cab 4x4 and have always had a drive shaft clunk and vibration. My friend has a newer Ranger ext cab 4x4 and it has a steel driveshaft. He has no clunk or vibration. Would a steel drive shaft help my problem? What year did they switch over and why? Will a newer one fit an 05?
Thanks for any help.
CWB90
The material used in the construction of the shaft is not the issue. You either have a worn out u-joint, or you need to re-grease the slip-yoke in the middle of the shaft.
his truck doesnt have a slip yoke in the mid shaft. solid aluminum like mine. but yea needs U joints, or has worn gears/splines
word need a new shaft, what years came with a carrier bearing?
whoa all of them? cuz mine doesnt have one thank god
I thought I read that the clunk was caused by the slip yoke not being greased correctly. Didn't Ford have a technical note about that?
Ok, let me expand on my original answer. Pre-98 supercab. Regular cabs are short enough to not need one.
There was a bulletin about it.
That or pinion bearing....my F150 always had that kinda "clunk" due to the pinion bearing
